02-04-2008, 08:41 PM
#1111
No.I painted my v6 white.
said it was a 2.5 but i think its a 3......and is the windstar lower any shorter??
2003 Oxford White Cobra #3328 of 8394
SOLD
02-04-2008, 08:43 PM
#1112
No, it is taller.
-Nathan
Mysteed Performance
Originally Posted by TBR
You're posting on a message board because you want to deliver input, and you'd obviously like your input to be valid. If this wasn't the case, you either wouldn't post, or you'd just smash keys with your computer turned off. Now, that being said, your opinion isn't based off who you are, it's how valuable your input is to the community and this is where grammar comes into play.
02-04-2008, 08:44 PM
#1113
well thats gay....it would take forever to get my plate redone
SOLD
02-04-2008, 08:48 PM
#1114
Then make due with it bro. What gasket are you going to run between the lower intake and the adaptor? Is it a paper gasket or a rubber gasket?
-Nathan
Mysteed Performance
02-04-2008, 08:53 PM
#1115
i guess the paper one cuz its not thick at all
SOLD
02-04-2008, 08:58 PM
#1116
Good call. Plus it's cheaper.
-Nathan
Mysteed Performance
02-04-2008, 09:01 PM
#1117
shew im worried it aint gunna fit....matt said he has a 2.5" plate with a .5" spacer and it fits under a 2.5" hood.....well i have a 3.0" plate and either a 2.5" or 3" hood so surely it will fit
SOLD
02-04-2008, 09:06 PM
#1118
My name is John
I really hope I dont have to get a 4 inch cowl for this m112..
Actually, I saw someone have just a stock gt hood with the m112. Ill look for pics and edit this post.
Here is the pic. It is from Tomzac's m112 car.
Also, here is a video of the m112 v6 with a stock hood.
http://videos.streetfire.net/video/6...4d01854b5b.htm
02-04-2008, 09:09 PM
#1119
tomzac.....fit under his scoop and he notched it out a little in front of the scoop
SOLD
02-05-2008, 08:51 AM
#1120
Dumbass. That's you.
Year: 2002/1966
Trans: 4R70W/M-21
Timeslip: slow/faster
****, that looks cool!
- 2002 Mustang 3.8 - 1966 Chevelle 454 - 1987 LTD 5.0 -
02-05-2008, 08:54 AM
#1121
What is the Mysteed for MOD kick?
02-05-2008, 09:11 AM
#1122
Trans: 5
Timeslip: 14.0@100
Originally Posted by mysteed
No, it is taller.
the Windstar, Mustang, and F150/E150/E250 lower intake manifolds are all the same height. It's the upper intakes that are taller.
02-05-2008, 09:31 AM
#1123
KeyBoard Cowboy
Trans: 5-Speed
Okay, 2 "small" updates guys.
1: I'm giving the guy that is making the prototype till the end of the week to be finished. After that I will go to my secondary sourse who has done these intakes before.
2: Matt and I were talking tonight and we have figured out a way for you guys to keep the stock radiatior hose! So that means the swap will take even less time. In ordder to keep it we simply have to move the secondary idler to a different location.
#2 is very interesting im trying to wonder where it could be moved too. Cause i can't stand modding the radiator hose like i have done it is prone to failure once you cut it.
-Mike
M112 Cobra Six Project = 99% Complete. Engine turned over now I have a vaccum leak
02-05-2008, 09:41 AM
#1124
is yours still not finished ohio???.....and there was a pic a few posts back that showed the new idlers and the belt route
SOLD
02-05-2008, 10:42 AM
#1125
V6 car, V6 Truck
Year: 00V6/70M1
Trans: Built T5/WC T5
I'm working on the idler this week at my place as well. I'll keep adding stuff as we get it worked out. Some of the ideas that came out of the talking are going to be great.
~Matt
2000 Roush #5004 World's First M112'd 4.2L
1970 Mach 1 351W T5 swap
2001 Explorer Sport 4.0L SOHC Roots in progress
02-05-2008, 10:44 AM
#1126
hey matt that one idler abve the alternator you and nathan posted...was it coming off the alternator bolt??
SOLD
02-05-2008, 12:19 PM
#1127
Coulda Had a V8
how much can the m112 bracket be shortened and rewelded? if i were to do that could it possibly fit under a stock or termi hood?
02-05-2008, 01:32 PM
#1128
KeyBoard Cowboy
Trans: 5-Speed
no not yet. ran short on funds. but im up and rolling again. I plan on getting it dynoed this spring and I will be making my own m112 thread once i get a few more items finished
-Mike
02-05-2008, 02:09 PM
#1129
V6 car, V6 Truck
Year: 00V6/70M1
ZERO - If we could have gone lower we would have. It has to clear ERG, Coolant lines and most importatly the stock fuel rail. That is really the limiting height factor. The fuel injector length requires the rail to be a certain height off the heads. Without major changes, it's got to be where it's at. If you wanted to invest in modification to make it lower - you'd defeat the idea of making it cheap and easy.
~Matt
02-05-2008, 02:13 PM
#1130
V6 car, V6 Truck
Year: 00V6/70M1
A note on Tomzac's set up: He modified the fuel rail alot to get it to sit that low. I didn't want to have that to mess with to keep it simple and easy for any owener to self install.
I ran mine just like that (without the added pulley between the alt and the blower). That idea popped up the other night. It would have to be mounted off the alt bracket in theory. I'm also working on another solution today. I'm getting side tracked trying to do a full new exhaust and revamp the front suspension at the same time.
~Matt
02-05-2008, 02:43 PM
#1131
If you do the radiator hose right it won't fail. Mine has been in it's current condition for over a year and it's just fine.
Sweet. Keep us updated.
Yes, but it requires a mod to the stock idler pulley, longer bolt, and a spacer.
What did he do to his fuel rails?
-Nathan
Mysteed Performance
02-05-2008, 04:20 PM
#1132
Coulda Had a V8
dont quote me on this, but i think he bent them back slightly
02-05-2008, 04:41 PM
#1133
My name is John
Yeah, on his cardomain, he said he slightly bends them.
02-05-2008, 10:04 PM
#1134
Always better in three's
Originally Posted by Rustyrodder
will there be a hotline if soemthing goes wrong?
i wish i still had the sixxer to do this
make one for a inline 6
Dustin 8-7
02-07-2008, 10:25 AM
#1135
V6 car, V6 Truck
Year: 00V6/70M1
Ok, sorry for not posting much - my parents place only has dial up and it kills me.
After looking more, I've made some adjustments, but the box still can't be made to go lower without a custom fuel rail and shorter injectors.... which if I remember right means you'll be getting 60 lbers.
Here's a shot of how I just ran my belt to skip the A/C pulley. I don't have A/C on my car anyway - it's just the delete pulley kit. This is without adding an extra pulley at all for those who want to go this route. Forgive only posting one pic - but seriously dial up isn't the way to go to load pics. I'll post more when I get back to MN this weekend.
My car has been at the shop for the past day getting some welding on the exhaust done - so I don't have it sitting here. But this gives you an idea. I alos have pics showing it from the side to see just how high it sits in the 99-04 bodys since the slope of the hood/line of the fender is different. I'll post that later as well.
~Matt
02-07-2008, 10:28 AM
#1136
Thanks for the update Matt. I see that you're still running the EGR and the DPFE stuff. Man you need to get rid of that junk asap.
edit: What belt are you running and what legnth is it?
-Nathan
Mysteed Performance
02-07-2008, 12:33 PM
#1137
V6 car, V6 Truck
Year: 00V6/70M1
Belt number is 5061075.
I kept the EGR and what not so it's still 100% smog legal and will pass an emissions check.
~Matt
02-07-2008, 12:50 PM
#1138
Coulda Had a V8
can i assume that in order for me to get this to work, ill need to get rid of my termi hood?
could someone possibly make a list of all the hoods that would fit the m112 so i know wut to buy?
02-07-2008, 12:57 PM
#1139
You're running a Dayco belt? It's only an inch shorter than the one that I'm running and I have a secondary idler and am using the AC.
I would assume that as well.
As far as I know, there is on way for us to see exactly what hoods fit as Matt has his blower off right now and my car is totaled.
-Nathan
Mysteed Performance
02-07-2008, 01:21 PM
#1140
Year: 2002/1966
Trans: 4R70W/M-21
^yup. which is why i decided to wait to order one. hate to spend 500 bucks and have to replace it...
