Go Back   3.8 Mustang Message Board > 1994-2004 Mustang Tech > 3.8L Powertrain Tech > Bolt Ons
Old 07-29-2007, 05:01 PM   #1
ray77
hood scoop mod, good or bad?
We got bored at work today and deicded to make his hood scoop functional. we took his scoop off and cut a hole in the hood, then put the scoop back on but w/o the rubber block thingy in the front. so its a straight shot to his engine bay.
we also took of the heat sheild from under the top of the hood. he said he could feel the heat coming out big time when he got home. now is this a dumb or good idea?
I guess it could keep the engine a lil cooler and work as a heat extractors at times, but i dunno. I might do it on my stang so i figuered id ask if he ****ed anything up.
ray77 is offline   Reply With Quote
Old 07-29-2007, 05:12 PM   #2
taylor0987
taylor0987's Avatar
Trans: 5
Timeslip: 14.0@100
Send a message via AIM to taylor0987
It really shouldn't hurt anything to remove heat from the engine bay.
Someone might tell you something about water when it rains. But your engine gets wet from underneath anyway....
Take a look at mysteed's and pintobeast's hoods.
taylor0987 is offline   Reply With Quote
Old 07-29-2007, 05:15 PM   #3
machoman013
xtecsystems.com
machoman013's Avatar
Not to mention someone on this board made theirs functional and it flew off while racing. To cool down my car I installed a 160 T-stat and had the tuner set the program to turn the fan on at 170F. My car never exceeds 179F in Houston stop and go driving.
366.03rwhp / 354.89rwtq conservative tune. http://www.cardomain.com/ride/2550233
machoman013 is offline   Reply With Quote
Old 07-29-2007, 05:20 PM   #4
pkupman_77
stock motor....for now!
pkupman_77's Avatar
HMM....I was thinking of drilling holes in mine
in that Black honeycomb front. Then putting a screen in behind it to be cleaned every now and then. but now maybe I won't.
Grey anthracite bullit rims, Steeda Cobra R Front Splitter...GT hood scoop....nothing else yet.
pkupman_77 is offline   Reply With Quote
Old 07-29-2007, 05:28 PM   #5
ray77
u still have to cut a hole in the hood.
so whats this about it flying off? that could suck.
Old 07-29-2007, 05:33 PM   #6
taylor0987
taylor0987's Avatar
Trans: 5
Timeslip: 14.0@100
is it just held down with adhesive? If so I'd bet adding a few screws/bolts would help to keep it from flying off.
umm, I think this fits better in bolt-ons than it does in engine tech, so I am going to move it there.
Old 07-29-2007, 05:56 PM   #7
ray77
u take the heat sheild off and its maybe 6 bolts u have to undo from underneth. so its already bolted down, but we did lose one bolt doing this mod.
Old 07-29-2007, 06:24 PM   #8
PalermoCorey90
Year: 2006
Trans: Autostick
Send a message via AIM to PalermoCorey90
got any pics
PalermoCorey90 is offline   Reply With Quote
Old 07-29-2007, 06:32 PM   #9
Taylor02GT
What the deuce?
Taylor02GT's Avatar
Model: Mustang GT
Trans: 4r70w
Send a message via AIM to Taylor02GT Send a message via MSN to Taylor02GT
Better reinforce that thing, id be afraid of it flying off.
2002 Mustang GT
Taylor02GT is offline   Reply With Quote
Old 07-29-2007, 06:33 PM   #10
ray77
we just did it today at work so no, not yet. i'll see if i can get some pics when/if i do mine.
Old 07-30-2007, 08:08 AM   #11
Rellik
is a dirty pirate
Rellik's Avatar
Year: 2008
Trans: 6-Speed Manual
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
Atmospheric pressures 1 inch above your hood aren't all that high to begin with.
Think of it this way, since this is the most visual example I can think of. When there is water on your hood and you're driving along, the beads of water aren't moving as fast as you're traveling forward... not nearly as fast. That is about 1/8". 1"-2 inches, above the hood the pressures are slightly higher, but you're not talking about 100 pounds of wind resistance either.
If you're going to do it, bolt it down in conjunction with automotive grade double sided tape (and for the love of god, trim it to match perfectly). The bolts will keep it secure, the tape will cushion the two for a water tight seal (except for the open front).
~~Evin - Forum Moderator~~
2008.5 True Red MazdaSPEED3 Sport ed.
Rellik is offline   Reply With Quote
Old 07-30-2007, 10:31 AM   #12
greensteeda
Speed Racer Mod. Suck It!
greensteeda's Avatar
Send a message via AIM to greensteeda
These are from before I really cleaned it up and made it smooth. I don't have any problems with rain but every once in a while a douche bag will throw some paper in there. Keeps things a good bit cooler though.
Sponsored by VAP Auto. www.vapauto.com
greensteeda is offline   Reply With Quote
Old 07-30-2007, 11:15 AM   #13
Kuplex
Timendi causa est nescire
Kuplex's Avatar
Timeslip: 13.42@103
Send a message via AIM to Kuplex
Even reinforced I've seen them fly off if they get enough force under them. If there is nothing but the regular mounts holding it on, I would strongly advise placing the honeycomb panel back on for support.
At the very least, you could drill out some of the holes in the honeycomb panel to retain it's original intent, plus it would reinforce the mounting at the same time.
Kuplex is offline   Reply With Quote
Old 07-30-2007, 08:48 PM   #14
ray77
thats basically what we did but with the gt scoop over the top if it
Old 07-30-2007, 09:33 PM   #15
outlawdstallion
Outlaw'd Performance
outlawdstallion's Avatar
hey greensteeda can you post some pics of the hoodpins located in your engine bay... are they drilled into the radiator mount or somewhere else? thanks
Sponsored by: Advance Auto Parts
outlawdstallion is offline   Reply With Quote
Old 07-30-2007, 09:40 PM   #16
ecdpres1
Trans: manual trans
i did thid mod about 2 years ago and haven't had a problem but i have the stock v6 hood
ecdpres1 is offline   Reply With Quote
Old 07-31-2007, 05:15 AM   #17
greensteeda
I don't know if I have any direct pictures of the pins but they go where the front hood bumpers go. You just unscrew those and bolt in the pins. Ill try to snap a pic on my lunch break or something
Old 07-31-2007, 05:25 AM   #18
BirminghamStang
Audi Guy
Year: 2003 A4
Trans: 5 Speed
Send a message via AIM to BirminghamStang
i drove mine around w.out the insert...and it was fine for a couple weeks....then it started to pull and crack where it attatched to the hood....so i took it off.. if i would have left it on any loner the scoop would have flown off
My Flickr My Space
BirminghamStang is offline   Reply With Quote
Old 07-31-2007, 05:57 AM   #19
Brandon
Better Than Sliced Bread!
Trans: Manual T-56
it really wont do much other than let rain water in... my hood scoops are designed to flow the most air they can on the hood and were put exactly where they are for that very reason... and they dont do much
2003 REDFIRE COBRA #3938 of 5082 @ 05/27/2003 1 of 414
Modification List, High Res Pictures, Dyno Sheet
440rwhp/483rwtq 10.9 A/F 12-15psi (new leaner numbers to come!)
Brandon is offline   Reply With Quote
Old 07-31-2007, 06:07 AM   #20
greensteeda
They do more than you think. If you have a thermo gun, block the vents one day and take the car through the paces. Then take a temp reading. Do it again with the vents open and you will see a noticeable difference.
Old 07-31-2007, 11:13 AM   #21
Zuplar
Unregistered User
Zuplar's Avatar
Model: Silverado
i really like the way this looks. what exactly did you use to cut it with? a dremel?
Link
Zuplar is offline   Reply With Quote
Old 07-31-2007, 11:32 AM   #22
greensteeda
yep, just took off the lining under the hood, popped out the plastic honeycomb and then cut out the fiberglass behind it.
Old 08-07-2007, 12:11 PM   #23
jdo009
jdo009's Avatar
Trans: manal
im lost... by removing the stuff under the hood heat shelding or what ever it is) then removing the blace honeycomb thing and dremeling it out to look nice. hows that have anythign to do with how the hood bolts down? from that hows that gonna make the hood fly off? other then putting alittle bit of upper lift from air going in the hood but i dont think its enough to make it fail is it?
jdo009 is offline   Reply With Quote
Old 08-07-2007, 12:25 PM   #24
S351_STALKER
Long time.
S351_STALKER's Avatar
Year: 04GT 98V6
Hood SCOOP will fly off
S351_STALKER is offline   Reply With Quote
Old 08-07-2007, 12:30 PM   #25
machoman013
xtecsystems.com
Even if you didn't 'think' it would happen; there's still a probable amount of failure. So bolt it down anyways. I mean, you wouldn't use a used t-lok with 50k miles if you could have a new one for only 5 bucks more?
Old 08-07-2007, 12:34 PM   #26
domin8
You've been warned
domin8's Avatar
Model: 5.4L Mustang 'GT'
Trans: 5spd.
lol worst mod ever. The previous owner did it to my gt and the scoop flew off on the freeway. IT was glued down and bolted and screwed and it still flew off. Then since i had a hole in the hood already i got the cdc shaker system. SO yeah, it WILL fly off
2001 Mustang GT: Forged 5.4 H/C/I, Shorties, O/R-X, Bassani Catback, IRS, Coilovers, and much much more...
domin8 is offline   Reply With Quote
Old 08-07-2007, 05:49 PM   #27
jdo009
jdo009's Avatar
Trans: manal
o ok now i understand... most of us with 6's dont have hood scoops we have that ****ty v6 hood
Old 08-08-2007, 03:56 AM   #28
V6 SSTANG
Part Time Racecar Driver
V6 SSTANG's Avatar
Trans: Big Stick
Send a message via AIM to V6 SSTANG Send a message via MSN to V6 SSTANG Send a message via Yahoo to V6 SSTANG
I woudlnt do it to my car
V6 SSTANG is offline   Reply With Quote
Old 08-08-2007, 05:06 AM   #29
greensteeda
I think its better because we don't have to worry about the scoops flying off.
Old 08-10-2007, 02:12 PM   #30
ray77
i proly wont do it to my car. ill wait and see if anything bad happens to my buddys. and i hate the v6 hood. i had to get teh gt one.
