Harness/Roll bar Tech
I’ve seen bits and pieces here and there about people buying harnesses, or roll bars for one reason or another, or for one purpose or another and it made me want to compile a list of what I feel are important information for all interested parties.
If you want to use a harness/racing seat/roll-bar there are things that you should know, and I’d like to cover some of them. I cannot cover everything, but if this thread evokes a discussion then maybe the topics I cannot cover will come up on their own.
__________________________________________________ _________________
The very first thing is general rules of thumb when using harnesses/roll bars.
1)Harnesses (with the exception of the DOT approved Schroth 4pts, which I’ll get into later) are not approved for street use, so you should never use them as a replacement for your factory belts.
With that in mind…
2)Not all seats are compatible with both the factory belts and harnesses. Deciding to use one or the other, or an aftermarket seat is a compromise you may have to make.
(one way to get around this is to sometimes unbolt the factory belt and run it through the
harness holes in the seat, however this does not always work)
3) This is VERY important: You should
never install harnesses without the use of roll over protection. I’ll get into detail below on how 3,4,5,and 6pt belts work, but in short look at it this way; if you run a
harness and no roll bar/cage and you flip the car
you=broken-neck=dead.
__________________________________________________ ________________________
Now that we got that out of the way let’s get in detail on each.
Harnesses/Belts:
Not all Harnesses are created equal! And right along with that, not all designs (3pt,4pt, etc) are safe.
Believe it or not your factory 3pt belt is safer than some out on the market.
So there are four different types of belts:
3point
http://www.fhp.state.fl.us/PhotoGall...s/PG102703.jpg
4point(the infamous DOT approved Schroth “
harness”):
http://m3.madrussian.net/diy/schroth_rally4/21.jpg
5point:
http://www.dougrippie.com/images/racing_seat.JPG
and
6point:
http://www.nurburgring.org.uk/trip_r...-harnesses.jpg
Now in the event of a straight on collision (like contacting the wall) each belt will work differently, and as follows:
3point: Will allow your upper torso to move forward, hit the air bag, and then will send your body down (submarine) under the lap belt (see how this keeps you safe in a roll over?).
4point: Will try to not allow your upper torso to move forward, however since there is no anti-submarine strap (otherwise known as a crotch strap) the lap belt will rise and allow you to slip underneath it. The crappy “DOT approved” Schroth belts are notorious for causing injury because two things happen. First is the shoulder belts stretch and fray, and then the lap belt yanks up your stomach and has ripped some people up)
Here’s a link to an incident where a guy in an STI hit a wall on an open track course. Both he and his instructor were wearing those great Schroth DOT 4pt (insert sarcasm here) the shoulder belts became so stretched that they submarined quite badly, and both ended up in the hospital. I believe both ended up in a coma.
“Both passenger and driver were wearing open face helmets. Driver hit sparco steering wheel, bending it. Passenger was a female who went under her shroth 4pts and was found in the footwell area. People said he was going maybe 80+ into the wall. Really sucks, especially since it’s a very small wall in the big stretch of open land. One of the instructors said they were both in stable condition, but looking at the sti up close made me feel that it was much worse. The driver side area was pretty bloody. Steering wheel, dash and harnesses had blood on them. My friend even saw a bloody sock nearby. Both were airlifted”
http://forums.nasioc.com/forums/showthread.php?t=800056
http://www.jtuned.com/forums/showthread.php?t=786
http://www.corner-carvers.com/forums...oth#post337904
5point: the anti-sub strap will keep the lap belt down and tight so the shoulder straps can be cranked down hard so you do not move forward, side to side, and you will not slide down (if installed correctly).
6point: the 6 point will do everything the 5point does, only a bit better. Since the dual anti-sub belts wrap around your legs they hold you in place better than the one crotch strap.
Belt Mounting:
The best way to mount the belts is to the factory mounting points for the lap belts, and to a horizontal tube attached to a roll bar/cage for the shoulder straps.
A crotch strap (or any strap that must go through the floor) should be backed on either side of the floor by a 6” diameter 1/8” thick plate and a MINIMUM of grade 8 hardware used, however I recommend aircraft grade.
The angle of the shoulder straps to the roll bar should not exceed 45degrees as to avoid compression of the spine.
__________________________________________________ ____________________________
Roll Bars/Cages:
Ok so now you’re decided that you want to spend more time on the track and have found that either dictated by class rules, car, or yourself that you need harnesses; which furthermore means that you need some form of roll over protection.
The very first thing you should do is pull out the rule book for the type of racing/events you plan to participate in and build it/have it built according to those rules.
What’s the point in having this bling bling, great cage/bar built if it’s illegal in the place you want to use it right?? RIGHT!
Typical rule of thumb in most classes is that you cannot modify the floorboards to fit tube,
http://homepage.mac.com/thomasmoran1...935F2D11D8.jpg
And
every tube that terminates on the body must be welded to a plate and then to the floor.
That is to spread loads so you do not rip up your floor.
Wrong:
http://homepage.mac.com/thomasmoran1...5D5F2D11D8.jpg
Right:
http://www.dariusrudis.com/mustang/r...s/mvc-140f.jpg
The main hoop and rear bars of a roll bar/cage should be
welded to the car. A bar will not protect you in a crash or roll over if it rips the bolts out of the floor,
weld it!
Diagonal and horizontal
harness bars can be removable if desired, and as long as the mount is strong you should be fine.
http://memimage.cardomain.net/member...0_208_full.jpg
http://memimage.cardomain.net/member...0_209_full.jpg
So how’s this for installment #1?
I’ll see what questions are left after reading this and if need be I’ll make another installment.
Matt
Edit: One last request please. I think we will end up sticking this so please try and keep to the topic, thanks.
