Go Back   3.8 Mustang Message Board > 1994-2004 Mustang Tech > 3.8L Powertrain Tech > Power Adders > Archives
Old 12-22-2005, 10:58 PM   #1
JayLS5
JayLS5's Avatar
Trans: Tee Fizzle
Send a message via AIM to JayLS5
Have questions about the M90 SC? Come here first.
I'm getting really sick of seeing the same questions over and over again, so made a write up.
The supercharger:
The M90 supercharger is an older OEM ford blower made by Eaton. It is a roots style blower with the following characteristics:
The M112 blower WILL NOT WORK WITHOUT MAJOR FABRICATION.
The M90 was put on ford thunderbird SC models and cougar XR7's. They come intercooled from the factory, a very crappy one.
This was my modified SC engine from a year or so ago: http://www.radford.edu/~jseemuell/engine.JPG
It was originally produced in 1989. All were underrated. The 89-93 model setups have very poor flowing characteristics: blower's inlet, the inlet plenum, rotors, etc.
The 94-95 SC engines were upgraded. The plenum was improved, the rotors were Teflon coated for reduced temperature, and the throttle body was enlarged to 70mm from ~60mm to match the plenum. The 89 style received 30lb injectors and the 94-95 is 36lb with a better fuel pump. The setup was so more efficient that Ford put on a larger blower pulley to achieve the same boost levels that the previous models had received, and got a little more power. The 89-93 models were rated at 210hp/315tq, and the 94-95 were 230hp/330tq.
Most people end up finding the less efficient style for the swap. If you decide to run the stock 30lb supercoupe injectors, you will be limited to about 265whp and 350tq – not too bad.
The stock boost is between 10-12 PSI, which depends on how well the engine flows. Of course, you have a large array of pulleys to choose from to put on your setup. An OEM 94-95 style on an 89-93 blower will reduce the boost 1-2 PSI. Conversely, an 89-93 OEM pully on a 94-95 blower will raise stock PSI by 1-2. Overdrive pulleys are available for each kind. One just has to use common sense; the 10% 89-93 style overdrive pulley will obviously be the smallest (the one in my engine picture). More overdrive is not necessarily better, as the already weak intercooler and crappy flowing parts get heat-soaked quickly. I wouldn’t even bother with a 10% on a near stock engine due to the immense heat increase that would negate much of the gains over the 5%.
More info: (mainly single port stuff, but important information as well)
Assuming you are just doing the swap onto your stock short block, you MUST upgrade the injectors and fuel pump. You MUST have dual exhaust at a minimal, or you greatly increase the chance of head gasket failure. The 94-95 V6 mustangs are a little easier to swap because the 96-98 changed a few things. The 94-95, however, should definitely consider using the supercoupe heads. The valvesprings are stronger, it flows a little better, but most importantly, it has improved cooling passages which greatly decreased head gasket failure (95 stangs had a recall). The supercoupes had head gasket problems as well, but this can be attributed to their stock exhaust system. It was terribly designed with a 90 degree bend and poor flowing parts... which netted an end result of 15psi of backpressure. Thankfully, a simple GT take off system will due for our cars, and we basically have shorty headers straight from the factory (as opposed to the SC's log style manifolds). Other than fuel and exhaust, we need a tune to go along with it after everything is assembled. These are the only NECESSARY factors; cam, rear end, high stall, clutch, etc will simply compliment the setup. Obviously, with an engine of this power, stock parts are more likely to break. If you have the ability to upgrade things while you’re in there, do it. Preventative maintenance is a good thing.
Split ports:
The stock fuel system is a bit better, but I honestly wouldn’t risk keeping this stock either. You must switch back to the return style fuel system anyway (255lph walbro is good). Of course, a tune is required. As we all know, split port mustangs have different manifolds and heads that offer much better flow over OEM single ports. In order to get the M90 to work on your car, you MUST go back to single port. This isn’t necessarily a bad thing, since there are several companies that offer single port heads that compete with PORTED split port heads. Big valve single-port heads would be a great improvement in flow over your stock split port engine’s. The only other setback of the single port design was the maximum throttle body size (60mm) that was limited by the upper intake manifold. Thankfully, the blower replaces this manifold and the inlet plenum connects to the throttle body. Even the stock, poorly flowing, 89-93 design plenum can be ported to accommodate a 70mm TB. The rotating assembly is comparable if not better than the supercoupe’s, so the splitport short block is actually preferred.
How to: (UPDATED)
A guy on V6 power has already done a great write up (general overview) with several pics included.
http://www.v6power.net/forum/viewtopic.php?t=10857
Found a radiator hose that fits perfectly:
Upper Radiator hose from a 1992 Buick Roadmaster (if it matters its an estate wagon)
Changing the throttle cable is NOT NECESSARY! Slight "ghetto rigging" required, but it's definitely possible. I'll have pictures of it sometime soon.
Potential modifications:
One of the best parts about this engine is the platform! It is extremely easy to make power with these motors. Intakes, throttle bodies, inlet plenum/blower packages, raised supercharger tops (stock ones suck, the one featured in my picture is upgraded), two stock intercoolers welded together (aka dual IC), front mount IC’s, 600ish CFM intercooler fan (cheap 10hp on stock IC), etc etc etc.
Two places i can think of off of the top of my head are
http://www.supercoupeperformance.com/
http://www.magnumpowers.com/
:update:
This is a comparison between one of the aftermarket blowers offered by magnum powers (no longer their best model, but it serves as a basis of comparison).
The magnum powers blower is much better because they attach a new inlet and matching plenum, better rotors, and port the V opening. You can see how you can sort of do your own mild porting on your blower if you're careful with it.
Thank 8ate8 from SCCOA for pics.
Magnum Powers II blower vs 89-93 style factory M90
http://www.3.8mustang.com/forum/atta...1&d=1138229364
Freebie modifications are great. While you are swapping this whole thing over, it’s very easy to gasket match and port the lower intake manifold (and heads if you want). The plenum can be ported significantly to support a 70mm throttle body. The blower “V” can be expanded a bit to increase flow. Also, the blower’s silencer ports can be welded up, which increases the noise and power.
Where to buy?
Most “complete” supercoupe swap kits are missing at least one or two miscellaneous items. I have seen people offer them anywhere from $250-700 on forums.
The best idea is to buy the whole motor or even the car. I paid $350 for a running supercoupe with high miles (but rebuilt top end and blower, the only thing that matters to me). Ebay and autotrader is the way to do it. One of the benefits of having the entire motor, besides having all the parts on hand, is learning how everything is put together as you take it apart.
Summary: It’s a LOT of work. It takes a LOT of time. It will cost about $1000-1500 if you are running a completely stock mustang with single pipe exhaust. In the end, a relatively stock SC setup can put you into low 14’s with near 100mph traps. A particular individual on this site that is a bit tired of being asked questions did this swap. It’s a single port auto, stock mustang short block, minor V porting on blower- not hard, stock GT exhaust, 2.73 open differential with BEYOND crappy tires. His best time was a 14.3x at 98.x
Those are 99-04 GT times, and he has enormous potential for improvement.
JayLS5 is offline   Reply With Quote
Old 12-23-2005, 10:57 AM   #2
94blkstang
wanna get boosted
Trans: AODE (for now)
good info jayls5 - happy to see a sticky about this topic.
thanks
Rich
1994 black 3.8
I think your wasting your time modding your 94 V6 for performance. 94s are slow
what was i thinking then ?
94blkstang is offline   Reply With Quote
Old 12-24-2005, 07:50 AM   #3
tomzac
232 or 330
Trans: gears, always
Are those the slots on either side of the V exit port?
EDIT: Is this a stupid question?
332/365@10.2psi
tomzac is offline   Reply With Quote
Old 12-24-2005, 10:59 AM   #4
94blkstang
wanna get boosted
[quote=tomzac]Are those the slots on either side of the V exit port?
QUOTE]
yes
1994 black 3.8
Old 12-24-2005, 11:23 AM   #5
95bstallion
H/C/I 5.0 FTW
Year: 1995, 2000
Model: v8 swapped 95 and 2000 GT
Trans: manual x2
I'm kinda curious where the 1000 dollar number comes from....Tune(chip,flash tuner at minimum, Fuel pump, Gt take offs and the actual supercoupe parts ?
Great write up though!!!!!
95bstallion is offline   Reply With Quote
Old 12-24-2005, 12:48 PM   #6
JayLS5
JayLS5's Avatar
Trans: Tee Fizzle
It's just a general estimate. Some might be able to pull it off for less, some a bit more.
This is for the bare essentials to get it running. Exhaust, pump, tune, SC parts
Fuel pump is about $100 for a 255 walbro, use stock 30lb SC injectors. Exhaust shouldn't be more than $200 if you go to a mom and pop shop. I used $350 as the basis for the SC parts, since that's what i got the whole car for. Throw in a $400 for Xcal2, some have local tuning shops that can do it cheaper. Add it all together, and it's in that ball park range.
Old 12-24-2005, 02:07 PM   #7
95bstallion
H/C/I 5.0 FTW
Year: 1995, 2000
Trans: manual x2
I was really just curious for other people that may have questions about the 1,000 dollar tag.
Old 12-27-2005, 09:41 AM   #8
trevradman
Inspired by Jay-Z---->
trevradman's Avatar
Year: 96
Trans: 5 Speed
Send a message via AIM to trevradman
Great write up! Thanks from us all! Now, lets start a rule where if someone asks a question that is answered in the sticky they get banned.
96 3.8, Eaton M90 Supercharger, Intercooled, 30lb injectors, Diablo Revolution, True Dual with magnaflows, CAI, slammed, Jamex Shocks/Struts, Fosgate 500 Baby! Ti 12" 5 NET CF tuned to 33HZ, 4g wiring, Spoiler, Rally Stripes,Vent Visors, tint, A/F and Boost gauges on the pillar, and a few other little things.
trevradman is offline   Reply With Quote
Old 01-05-2006, 08:17 AM   #9
Judicator
YOUR_MOM
Judicator's Avatar
thanks
Rich
yes, thank God. and great resource!!!
www.car-part.com is a great place to find motors, parts, etc. in your area!!!
for the off topic *****en
Judicator is offline   Reply With Quote
Old 01-17-2006, 10:15 PM   #10
JayLS5
JayLS5's Avatar
Trans: Tee Fizzle
Made a minor update on installing it
Old 01-25-2006, 02:51 PM   #11
JayLS5
JayLS5's Avatar
Trans: Tee Fizzle
Click image for larger version
ID:	86227  Click image for larger version
ID:	86228  Click image for larger version
ID:	86229  Click image for larger version
ID:	86230  Click image for larger version
ID:	86232  Click image for larger version
Old 05-06-2006, 08:08 AM   #12
V6mustang94
Send a message via AIM to V6mustang94 Send a message via MSN to V6mustang94 Send a message via Yahoo to V6mustang94
How much power to the wheels would you expect if you put the supercharger on, do all the necesities, and do the T-bird heads? All this would be from the 94-95 model and I'd be using my current motor.
Xbox Live: Soundless MNStangs.com
V6mustang94 is online now   Reply With Quote
Old 05-06-2006, 01:07 PM   #13
94blkstang
wanna get boosted
re read the what jayls5 has written as it is stated
1994 black 3.8
Old 05-06-2006, 02:37 PM   #14
Duke
(̅_̅_̅(̅_̅_̅_̅_̅_̅()ڪے
Duke's Avatar
Year: 0098
Trans: TR-5
supposedly around 200+ whp and 300 wtq
Duke is offline   Reply With Quote
Old 05-09-2006, 08:24 PM   #15
V6mustang94
That's on the T-bird. Not a mustang.
Old 05-10-2006, 02:27 PM   #16
JayLS5
JayLS5's Avatar
Trans: Tee Fizzle
about ~200whp and ~320tq through an automatic
Old 05-11-2006, 01:36 PM   #17
V6mustang94
How about if I did the whole motor? If I do this I'd much rather put in a whole engine.
Old 06-17-2006, 11:32 AM   #18
68COUGAR
How did you come up with 15 psi of backpressure? How was it measured? Just Curious.
68COUGAR
68COUGAR is offline   Reply With Quote
Old 07-22-2006, 07:45 PM   #19
JayLS5
JayLS5's Avatar
Trans: Tee Fizzle
68COUGAR
Took it straight off of a FAQ on www.sccoa.com
Old 07-28-2006, 08:57 AM   #20
6forlife
6forlife's Avatar
Year: 1996
Trans: manual
im doing a whole engine tranny swap and dont know what parts wont match up on my 96 sep an oil lpug and knock sensor. anything im missing??
6forlife is offline   Reply With Quote
Old 07-28-2006, 04:05 PM   #21
94blkstang
wanna get boosted
do not use the tranny from a sc it will not fit with alot of mods and you will be shift really far back.
1994 black 3.8
Old 09-23-2006, 09:37 PM   #22
1SLOSN95
1SLOSN95's Avatar
Trans: 4r70w-
Send a message via AIM to 1SLOSN95
So what tranny would you use then?
Show: Starfish Wheels (GT wheels in Sig got stolen)
GO: POS densecharger, MAC underdrive pulleys, MAC longtubes, MAC offroad H-pipe, FRPP aluminum driveshaft, 3.73 gears, and POSI. Screamin Demon Coil pack, 9mm Live wires
In the worx: 5.4 DOHC
1SLOSN95 is offline   Reply With Quote
Old 09-28-2006, 09:36 PM   #23
JayLS5
JayLS5's Avatar
Trans: Tee Fizzle
The mustang's.
Old 10-17-2006, 10:17 PM   #24
GakiAkuma
Great info but what is the best year for the SC?
Wheres the best info for the SC? I may just go with a supercoupe(sc) instead of building a mustang up.
Why make something that already has what your looing for ya know.
GakiAkuma is offline   Reply With Quote
Old 10-18-2006, 12:18 PM   #25
94blkstang
wanna get boosted
imo it's the 94-95 but alot of other ppl like the 89's not sure why? the reason i woudl not do the sc up is because it weights a TON
1994 black 3.8
Old 10-18-2006, 12:49 PM   #26
JayLS5
JayLS5's Avatar
Trans: Tee Fizzle
The 94-95 plenum and blower is better.
The supercoupe weighs about 800 pounds more, and simply throwing a stock SC setup into a mustang will be outrunning some modded supercoupes. Low 14's at around 100mph.
Old 10-18-2006, 12:55 PM   #27
GakiAkuma
Yes they do weigh quite a bit, but I see the 2.3t turbocoupe guys making some good numbers with theres, Iam sure I can do alot to drop the weight a good bit, is gonna cost an arm and a leg but I thnk it can be done, becides I play to road race so I think it would be allright
Old 10-18-2006, 01:31 PM   #28
JayLS5
JayLS5's Avatar
Trans: Tee Fizzle
I'm fairly certain the turbocoupes were lighter. They had a completely different chassis.
The weight of the supercoupe is in the essential parts of the car. The suspension system is heavy, along with every major part. Just swinging the doors on them you realize it's a brick on wheels.
Old 10-18-2006, 02:57 PM   #29
GakiAkuma
Yeah when I find one Iam gonna take as much crap out as possable. I like A/C but Iam pritty much used to not having it except in my house.
the spair tire and ect is replaced with a can of fixaflat and a AAA card.
back seat is gone, I like music so I need to keep the radio but replace it with new lighter compnents.I see a couple companies make fiberglass hoods, but no decklids...
Iam sure I could shave 500 lbs off of it and still keep it a comfertable diver.
Old 10-18-2006, 03:25 PM   #30
JayLS5
JayLS5's Avatar
Trans: Tee Fizzle
Hah, good luck with that. If your serious about it, the A/C will help a little. The seats are a big one, bunch of motorized parts in there. They were like 60 pounds each. I highly doubt you'll end up cutting 500 pounds though.
